midtskogen
Sep 27, 2012Aspirant
Web interface doesn't see second drive, Linux does
I just bought a Duo V2 with two WD Green 3TB. However, when I boot up, the web interface claims that there is only one disk, 2.7TB. I'm running RAIDiator 5.3.6. To investigate, I enabled ssh acce...
flyvert
Sep 29, 2012Aspirant
My two WD Green Caviar 2TB disks broke the 300.000 LCCs (head parkings) marker in less than a year.
Some say the LCC MTBF is around 300.000 for these disks... :(
Green Caviar disks may not be ideal for NAS 24x365 use since they park their heads after just 8 seconds.
I recently got both disks replaced on warranty, and since setting the IDLE3 setting to 254 (>1 hr) on the replacement units, the LCC counters does not move in thousands every day. I've configured my NAS to spin down the disks after 1 hour of idling.
If I were you I'd definitely do something to prevent the disks from hitting supposed MTBF figures prematurely.
/f
/f
