vk4akp
Jun 14, 2015Aspirant
Web interface for Offline Use?
Hi, I'm off to buy a Netgear RN10400-100AJS tomorrow. My question is. Do these have the usual normal Web interface via the devices IP address? Our application is for "Offline" use. IE. ...
mdgm-ntgr
Jun 14, 2015NETGEAR Employee Retired
Yes, you can use these without an internet connection. There is a web admin interface accessible via the device's I.P. address. This I.P. should show on the LCD on the front of the NAS (if the LCD is off you can turn it on with a momentary press of the power button). Also on your DHCP server e.g. router you should see the MAC address of the NAS and associated I.P. in your attached devices list.
You won't be able to use the Cloud features e.g. ReadyCloud, but services not relying on an internet connection will work fine.
I'm a little curious. What do you intend to use the RN104 for? Most home users wouldn't connect a NAS unit to a LAN with no internet connection.
