vk4akp
Jun 14, 2015Aspirant
Web interface for Offline Use?
Hi, I'm off to buy a Netgear RN10400-100AJS tomorrow. My question is. Do these have the usual normal Web interface via the devices IP address? Our application is for "Offline" use. IE. ...
c3po
Jun 15, 2015NETGEAR Expert
RN104 and RN314 use 4-pin Kycon connector: Pin 1 and 2 are 12V; Pin 3 and 4 are Ground.
https://en.wikipedia.org/wiki/DC_connector#4-pin
http://www.kycon.com/Pub_Eng_Draw/KPPX-4P.pdf
You can ALWAYS check pin out on power adapter itself. The pin out marking is required by safety regulations.
As long as you can find proper Kycon connector for your power source, you should be able to run RN104 on your 12V power source.
(This reminds me of cutting old connector from broken power adapter and connect it to newer power adapter with incompatible connector)
