renoir13's avatar
renoir13
WebDAV on ReadyNAS Duo v1 not responding to WAN connections
Hi,
I set up WebDAV access on a ReadyNAS Duo v1 running firmware v.4.1.14. I followed the instructions as stated here, including installation of mentioned webdav patch. I configured a share to be accessible via WebDAV (https). I set up a domain name pointing to my public IP address, I opened port 443 tcp in my firewall and forwarded it to the NAS' IP address. However, I am not able to establish a webdav connection from wan via https://subdomain.mydomain.tld/sharename using ES Explorer on Android. ES Explorer tells me, server not found.
What puzzles me is that I am able to establish a WebDAV connection from lan using exactly the same configuration. I am also able to access the NAS' admin page from wan which tells me that port forwarding is working as it should.
Any help is highly appreciated.
renoir.
  • StephenB's avatar
    DId you try the android device's browser?  That might give a clue.
    • renoir13's avatar
      renoir13
      Works just fine, after the usual self-signed certificate warning.
      • StephenB's avatar
        Ok.  So the connection is working fine.
        Perhaps ES File Explorer is choking on the cert error??? Or a typo in its webdav server config???
        I set it up to use ftps myself (which works fine, and is also encrypted).
ProSupport for Business
