fmcstit
Oct 20, 2015Tutor
Weird Problem - ReadyNAS 314 - no volumes exist error but my shares show up and I can't access them
Greetings, I'm not sure what caused this to happen but below are details of what is transpiring. ReadyNAS 314 4 WD 2TB RED drives in X-RAID RAID 5 configuration I can access the GUI Volum...
Oct 20, 2015Guru - Experienced User
Did you try shutting down and disconnecting the RN314 from power for a bit? Some SATA errors might lock the bus interface.
If that doesn't work, then perhaps contact support. You might need a data recovery contract (though it is possible that one of the missing drives can be reconnected to the array).
- fmcstitOct 27, 2015Tutor
StephenB,
Thanks for your response. I did disconnect the device from power for 2 days, but once turned back on I have the same problem. I have an open ticket with Support but to date no resolution. All 4 disks are inserted but only disk 1, 4 are detected and I can still "see" the folders through Windows file explorer, but no access. Hopefully there is some way to force the device to recognize the drives without reformatting and losing all the data. Thanks
- carlfredrikmDec 13, 2015Aspirant
How did you solve it?
