Clarkson
Dec 21, 2013Aspirant
What digital format
Hi Iam starting to digitise my DVD collection. Trying ti find the right format. I have ipad, playstation 3 , I phone 5 and laptop with windows. I wouldn't mind some compression for streaming and...
xeltros
Dec 26, 2013Apprentice
Ah ? they reintroduced it in AVPlayer HD ? I believed it was squeezed in every app of the store along with DTS. Then it may be a better choice than buzz indeed.
I have no preference between AAC and MP3, as long as you go higher than 192kbit/s both are fine, compression ratio is not exactly the same (AAC is preferred at lower bitrate) and purist say the sound is not the same that each codec has his own sound color. To be honest I never heard any difference between MP3 320kbit/s (lame encoder) and AAC 256kbit/s (itunes).
