28ToM47
Feb 26, 2014Aspirant
What to do after a fail firmware upgrade ?
Hi, (sorry for my poor english ..) - Today, i've connected myself to my readyNas Web Dashboard. - A pop-up showed up and said : "do you want to upgrade from 6.1.3 to 6.1.6" (or something like t...
vandermerwe
Feb 28, 2014Master
I agree that the support on the forum is excellent.
If you bought a Volkswagen and Volkswagen said to you "We advise you to use the original engine; if you change it, things may not work properly and we will not be prepared to help you if something goes wrong"; would you go ahead and change the engine and then expect them to help you?
I personally don't think Netgear are being that unreasonable.
4.1.x is not as pretty as OS6, but it works well, I don't think anyone on the forums would advise using OS6 on a legacy device that contains your primary data.
