Manwithamission
Aug 13, 2016Aspirant
Which bays should I use?
Hi, I have just installed three 6TB drives in my new 316. I couldn't find a particular order 1-6 for the bays so I put them in the three lower bays thinking lower center of gravity-less vibration. ...
- Aug 13, 2016
You can install HDD in any sequence and in any slots.
From HDD cooling point of view use 1,3,5 slots for 3 drives.
sotrack
Aug 13, 2016Luminary
Aug 13, 2016Guru - Experienced User
FWIW, I don't think there much (if any) vibration advantage between the slots. Low Center-of-Gravity is more about being harder to tip.
I agree that is a good approach, but if the temps are good now there is no need to switch anything.
Manwithamission - what drive temps are you seeing? Also, what drive model are you using?
- ManwithamissionAug 13, 2016Aspirant
Temp seems fine. My second question was relating to wether it will screw the thing up if I put the drives in different slots? Do you know if this is done when the system is shut down will it have to resync everything or will it just pick up the drives in the different slots. Thanks
- StephenBAug 13, 2016Guru - Experienced User
Yes, I understood that (just didn't answer it).
It certainly will screw things up if you do it with the unit running.
Netgear routinely recommends recording slot numbers and putting drives back into the right slots when migrating. But I believe it will work fine if you shut down the NAS, shift the drives, and then power back up.
I always urge people to maintain backups, since it's clear if you look at postings here that RAID is simply not enough to keep data safe. I think its particularly important when you are manipulating disks - things can go wrong, including dropping them! Which I did once myself :smileyfrustrated:
FWIW, i see no good reason to move your drives around, so if the temps are good I'd just leave things as they are.
Thanks to all for answering my queary.
Nigel
