Zurd
Dec 24, 2017Star
Why encryption if there's already permissions?
Hi, I'm wondering why would I add encryption on a volume of a ReadyNAS RN214. What advantages would it give me? I did not check the recovery for admin password https://kb.netgear.com/22784/How-d...
Sandshark
Dec 26, 2017Sensei
The best way to use VeraCrypt with the ReadyNAS is toi run the program on your PC and just put the container on the NAS just like you would on an external drive. It is probably possible to install a Linux version of VeraCrypt on the NAS, but that's likely a lot more trouble with few additional capabilities.
Dec 27, 2017Guru - Experienced User
Yes. The encryption is only known by the PC, and the encrypted data isn't on the PC, but on the NAS. Both devices are needed to access the encrypted data.
There are some similar options, including using Microsoft VHDs.
The downside is that these approaches are usually designed for single user acess. Another factor is that if the NAS is only providing block storage, these volumes are difficult to back up. ReadyDR should work efficiently, but the other backup protocols in the NAS will back up the entire volume when it changes.
- ZurdDec 27, 2017Star
Thanks for all this good information, in the end I choose the encryption with the ReadyNAS. It's still pretty good, if anyone's stealing it without the USB key, he'll never be able to read the data. Just don't tell the thief that I have a USB key hidden arround :)
There's a slight performance drop with the encryption that way but really not that much, I'm happy with the end results.
