7lkf7
Mar 24, 2018Aspirant
Why My ReadyNAS PRO is 1T less than the Raid Calulator
Hi everyone, I did use the Netgear Xraid calculator configured my raid setup, three 4TB drives, one 2TB plus two 1TB drives in X-RAID . refer to Calculator I should get 10.9TB in total. but my real...
- Mar 28, 2018
Hi 7lkf7
You can perform factory reset if you want but make sure you have backed up all your data. You may want to wait for StephenB 's advise once the log has been checked.
Doing factory reset removes all data so make sure everything has been copied or updated. I'm pretty sure what the calculator is showing will be the same with your volume after the factory reset.
Regards
Marc_V
Mar 25, 2018NETGEAR Employee Retired
Hi 7lkf7
Welcome to the Community!
Did you had this setup when you factory defaulted the unit or was this an expansion?
- This tool is not a volume space simulator, so it will not calculate expansions. This tool assumes a factory defaulted state for each drive configuration.
So if it's an expansion there is a possibility that the calculation is different since the RAID calculator assumes that it is an initial setup or factory defaulted setup. There are also things to consider like the File system overhead and Snapshots so the RAID calculator is actually giving you an estimate of the RAID that will be configured.
We always recommend that the volume capacity to always have 20% free disk capacity to avoid performance issues.
You can allocate Snapshot space depending on what you need, You can always manage your Snapshots by properly configuring it according to your preference. You can also use Smart Snapshot to help you maintain your disk capacity.
You can also do volume maintenance to manage your volume and make sure everything is balanced and properly allocated.
Hope this helps!
Regards
