pvnnpavan
Jul 01, 2021Tutor
Why only 1st NIC is having heating issues and that alone taking complete network down on 21400 model
I can see NIC 1 is not working and NIC 2 is online but still network is not working properly.
Can we disable NIC 1 permanently and what other options do we have if NIC's are not working to connect to NAS to get data
- SandsharkSensei
You can disable both IPv4 and IPv6, but I don't know if that will accomplish what you want. I do not know if the 214 uses two completely independent channels for the two ports or has some dual-port devices. If it has the latter, heat from one channel could affect the other.
There is no other way to access the NAS, but there are methods of using other devices to recover data. Or, you can move the volume to a replacement OS6 NAS.
Do we know what exactly is causing the issue.
Since this issue is not there before v6 upgrades..
NAS is working perfectly fine 24x7 through out the year.
Is v6 causing these issues or any firmware upgrade to NIC's ???
