jreisenb
Jan 18, 2012Aspirant
Wired router issue with ReadyNAS Ultra
After trying all the usual "things to try", including all the Vista stuff, I submitted a ticket with the router group: 1/18/2012 4:46:00 PM Modem model: Netgear WNDR3400 PC model: Dell Insprion 5...
jreisenb
Jan 19, 2012Aspirant
StephenB wrote: I meant the internet browsing speed (both up and down)-comparing wired and wireless.
The idea is that the only difference between your wired and wireless test is the link between the PC and the router. (The link between the NAS and the router is always wired). So if you are seeing poor performance on the wired link, it is useful to know if it affects anything else. Presently your wired NAS speeds are much slower than your broadband speed.
Anyway, you are seeing quite a few receive errors. Maybe clear the stats, and then immediately run the wired test, then check the stats as soon as it completes.
Wired download is 4.3M and wireless is 3.9M. Upload is the same. I'm not sure how to reset the error counts but I'm seeing any additional errors this evening. Don't have a clue as to what it could be.
One question, when I copy MP3 files, it says it can't copy properties associated with the files...
Property Loss
Are you sure you want to copy this file without its properties?
Strange.
