GregPope78
Mar 17, 2016Aspirant
Wireless adapter for ReadyNAS PRO 6?
Greetings, I have a ReadyNAS Pro 6 and I need to connect it wirelessly to my network, however it is not convenient to have it connected directly the wireless router. Does anyone know if a wireless ...
mdgm-ntgr
Mar 17, 2016NETGEAR Employee Retired
No, the Pro 6 doesn't support wireless USB adapters.
GregPope78
Cheers, thanks for that.
Would an Ethernet to wireless adapter, like the IOGEAR Universal Ethernet to wireless adapter, work?
- mdgm-ntgrMar 17, 2016NETGEAR Employee Retired
If that adapter is doing all the work and doesn't rely on the NAS at all, I guess so, though I've never tried an adapter like that.
- StephenBMar 18, 2016Guru - Experienced User
It looks like it functions like a wireless bridge, if so it would work. However, that particular product looks quite slow (150 mpbs link speed). Something like this would run a lot faster: http://www.netgear.com/home/products/networking/wifi-range-extenders/EX7300.aspx#tab-idealuses Though of course this also depends on the speed of your main WiFi router. Which router model are you using?
Powerline might also work for you, but you'd need two units.
- JennCMar 18, 2016NETGEAR Employee Retired
Hello GregPope78,
The ReadyNAS USB ports are designed for USB disks only, legacy units' will work with printers too. USB adapters use have drivers and utility that will manage the USB adapter and ReadyNAS does not have capability of handling those. The best thing I can think of is connecting a wireless bridge like StephenB mentioned. WiFi extender that has LAN ports will also do, like this N300 WiFi extender.
