Nov 27, 2015Aspirant
A6210 Wireless Adapter Keeps Disconnecting
Every 30-40 minutes or so, my A6210 wireless adapter is connected to the router, but not the Internet. This is for around 2-3 minutes before the adapter connects back to the Internet. How do I fix this issue? I constantly get disconnected from any online games I'm in and it sucks. During this 2-3 minute period, the Internet on my other devices works fine, but not on this PC. I'm also using WIndows 10 and have the latest firmware of Netgear Genie, 1.0.0.34.
If you have anti virus or firewall, try to uninstall it for the meantime and observe the connection. If still the same, I would suggest contacting support.
- JamesGLNETGEAR Employee Retired
Hi 917,
Please try to install the standalone driver instead of the driver with Genie.
- 917Aspirant
Thanks for replying, JamesGL.
How do I install the standalone driver? While doing this will I have to uninstall the Genie driver?
Yes, you have to uninstall the Genie driver. The file you have downloaded in support site came with two drivers, the genie and the standalone.
