msteuernagel
Sep 24, 2012Aspirant
Workflow for archiving large amount of data
Hi, I'm new to ReadyNAS and to the forum, but I did several searches and could not find this information... I work in a small institute where we deal with a huge volume of video files, and we h...
Sep 24, 2012Guru - Experienced User
The NAS is not set up for swapping the drives in and out. One concern is that the sata connection scheme is not intended for heavy use. Also, if you hot-insert an old volume, you run the risk that the NAS will think it is a new disk, and will wipe it/resync.
It is best to archive your data to USB drives, and not swap out Volume D drives.
