JanOli4
Jun 02, 2017Aspirant
Wrong version of firmware loaded from Netgear
Hello, I am using my readynas202 for a year and had a hard disk crash on my laptop, restoring the data from the netgear was awsome, the 1 Gb line was very slow and I had to split the data in piece o...
Jun 02, 2017Guru - Experienced User
To be clear, this is a community forum, and I do not work for Netgear.
Can you confirm that you are running an RN202, and not a ReadyNAS Duo v2?
JanOli4 wrote:
As I see that Frontview is installed and this is an ARM equipted system, something is really wrong.
Can you tell me exactly what command you entered that tells you that frontview is installed?
"Frontview" does show up in OS 6 systems (both ARM and x86). For instance /frontview, /var/log/frontview and /etc/frontview all exist.
"Dashboard" only shows up as a subfolder of /frontview.
I not saying that there is nothing wrong. But trying to uninstall part of the Netgear firmware and then manually install some other part of Netgear firmware instead is not going to work.
We need more information.
JanOli4
Jun 03, 2017Aspirant
It is a ReadyNAS 202 , firmware version 6.7.1 according RAIDar.
The odd thing is that I read and write to my network virtual disk on the ReadyNAS, RAIDar says that every thing is Oke when I start a diagnose.
When I try to open the admin page from RAIDar I get inmediately the message:
This site is not rechable
192.168.178.* refused the connection.
If I open 192.168.178.*/index I get a query for an username and password, next thing is that it hangs after some time in a javescript Frontview-6.6.9174.js line 83.
If I open a SHH client on port 80 of 192.168.178.* I get a terminal window after a username password login and can see and manage everything on the Debian Kernel.
So there must be an error somewhere, which can be a wrong configuration file, wrong priveliges or a a wrong version of any program in Debain.
To find this will be very hard, so I tried already 2 times to restore the readynas OS by using the reset button on the device itself and do an OS reinstall, but this doesn't give any improvement.
As I don't have documentation of the internals of this device, the only sound solution is to reinstall everything, but I don't want to lose my data on the NAS as this is rather much and contains a lot of photo's, music, ebooks and other important data like my legacy database and my record collection database.
- StephenBJun 03, 2017Guru - Experienced User
The best way to prevent that is to back up the data on the NAS. I suggest that is the right next step.
After that, you could try a USB recovery, which would also upgrade the firmware to 6.7.4.
- JanOli4Jun 04, 2017Aspirant
Stephen,
This is the windows solution, if you build an OS which is so complex and unstructed as Windows this is a good solution.
But Netgear runs on a linux debian OS, which is more structured and it should be possible to find the problem.
Thanks for your support, but this is the last thing to do
I will debug the linux server and find why it refuses to act as a webserver, which is in fact the case as all other functionality works.
If I found the solution I will post it here
Regatrds jan Olivier
- StephenBJun 04, 2017Guru - Experienced User
I didn't build anything here - I don't work for Netgear.
Up to you of course, but I believe Netgear would also recommend USB recovery in your case (or paid support). Perhaps PM mdgm-ntgr (using the messages link in the upper right) before you proceed -he might have some specific suggestions.
