JanOli4
Jun 02, 2017Aspirant
Wrong version of firmware loaded from Netgear
Hello, I am using my readynas202 for a year and had a hard disk crash on my laptop, restoring the data from the netgear was awsome, the 1 Gb line was very slow and I had to split the data in piece o...
JanOli4
Jun 03, 2017Aspirant
It is a ReadyNAS 202 , firmware version 6.7.1 according RAIDar.
The odd thing is that I read and write to my network virtual disk on the ReadyNAS, RAIDar says that every thing is Oke when I start a diagnose.
When I try to open the admin page from RAIDar I get inmediately the message:
This site is not rechable
192.168.178.* refused the connection.
If I open 192.168.178.*/index I get a query for an username and password, next thing is that it hangs after some time in a javescript Frontview-6.6.9174.js line 83.
If I open a SHH client on port 80 of 192.168.178.* I get a terminal window after a username password login and can see and manage everything on the Debian Kernel.
So there must be an error somewhere, which can be a wrong configuration file, wrong priveliges or a a wrong version of any program in Debain.
To find this will be very hard, so I tried already 2 times to restore the readynas OS by using the reset button on the device itself and do an OS reinstall, but this doesn't give any improvement.
As I don't have documentation of the internals of this device, the only sound solution is to reinstall everything, but I don't want to lose my data on the NAS as this is rather much and contains a lot of photo's, music, ebooks and other important data like my legacy database and my record collection database.
Jun 03, 2017Guru - Experienced User
The best way to prevent that is to back up the data on the NAS. I suggest that is the right next step.
After that, you could try a USB recovery, which would also upgrade the firmware to 6.7.4.
- JanOli4Jun 04, 2017Aspirant
Stephen,
This is the windows solution, if you build an OS which is so complex and unstructed as Windows this is a good solution.
But Netgear runs on a linux debian OS, which is more structured and it should be possible to find the problem.
Thanks for your support, but this is the last thing to do
I will debug the linux server and find why it refuses to act as a webserver, which is in fact the case as all other functionality works.
If I found the solution I will post it here
Regatrds jan Olivier
- StephenBJun 04, 2017Guru - Experienced User
I didn't build anything here - I don't work for Netgear.
Up to you of course, but I believe Netgear would also recommend USB recovery in your case (or paid support). Perhaps PM mdgm-ntgr (using the messages link in the upper right) before you proceed -he might have some specific suggestions.
