DPIPIMHouse
Feb 07, 2012Aspirant
X-Raid Data Recovery
Hi, Please can someone advise how to recover the data off a single disk from a 2 disk X-Raid set up?? One of my disks died and since then, my Duo is now not booting. As you may have seen from my pr...
DPIPIMHouse
Feb 08, 2012Aspirant
All data lost. My own fault.
Ended up formatting disks and started from scratch.
I have some data backed up but I'm still gutted.
If anyone experiences the same issue, here's my advice........
- Remove both the defective and the good drive.
Check/Replace the defective drive.
Perform a Factory reset with just the replaced/blank drive in the Duo.
Plug in the good drive containing old data into the USB port. (USB does read X-Raid)
Copy Data back to device.
After copy and check, remove the USB disk and format it.
Place newly formatted disk into second bay to go fully redundant again.
Fixed.
