mthescorpion200
Jul 11, 2013Aspirant
Xraid 2 formatted disk
Is it possible to put a X-Raid 2 formatted disk (WD Caviar Red 3TB) into a caddy and read it as a usb drive?
mthescorpion200
Jul 12, 2013Aspirant
Yes it is for data recovery. My NAS started beeping however i didn't get any emails about disk failures so the OH turned it off. Turning it back on it is now stuck in the 'Booting...' screen. I can access the boot menu, have successfully run a memory check, it failed an OS reinstall and am currently doing a disk test. If that fails i guess my next option is to put them in a caddy as you said i could do.
I guess as they are mirrored it shouldn't matter which one i use. I should be able to copy them somewhere and do a 'Factory Default' install and copy it all back again.
