radioguru6613
Oct 22, 2015Aspirant
XRaid, XRaid-2, Raid-6, Raid-10 ????
Curious about something, on the RM3220 Volumes screen I see a box on the upper right with a green line through it that says X-RAID, under my graphical display of my NAS is shows the raid as RAID-6 (s...
- Oct 23, 2015
X-RAID is Netgear’s eXpandable RAID technology that allows you to expand the size of your hard drive both horizontally (by adding more drives) and vertically (by replacing smaller drives with larger drives).
x-raid2 is just version 2. in some firmware although ver 2 is employed the term x-raid is still used to distinguish from flexi raid
x-raid is default u dont have to select when set up, and if u have 4 disk or more the system will default to raid 6
of course u can turn to flexi raid by destroying the volume and choose other raid levels or no raid such as jbod
cpu8088
Oct 23, 2015Virtuoso
Oct 23, 2015Guru - Experienced User
Unless something just changed, the default xraid2 settings are single redundancy (RAID-1 with 2 disks, RAID-5 with more than 2). It will not default to raid 6, that needs to be set up manually.
- radioguru6613Oct 23, 2015Aspirant
StephenB wrote:
cpu8088 wrote:x-raid is default u dont have to select when set up, and if u have 4 disk or more the system will default to raid 6
It did ... my screen shot is an out of the box unit freshly populated. It went right to 6 not 5.
- john_h1Oct 26, 2015Tutor
I was wondering about this as I just upgraded my ReadyNAS Pro 6 (6 x 3 TB hard drives).
Under Raidator 4 I had dual redundancy and had about 10TB of storage.
under OS6 it says X-Raid / Raid 5 so it set up with single redundancy. Is there a way to convert it over to dual?
- cpu8088Oct 26, 2015Virtuoso
destroy existing volume and then recreate new volume
u would need to backup your data before that and then restore to your new volume
