radioguru6613
Oct 22, 2015Aspirant
XRaid, XRaid-2, Raid-6, Raid-10 ????
Curious about something, on the RM3220 Volumes screen I see a box on the upper right with a green line through it that says X-RAID, under my graphical display of my NAS is shows the raid as RAID-6 (s...
- Oct 23, 2015
X-RAID is Netgear’s eXpandable RAID technology that allows you to expand the size of your hard drive both horizontally (by adding more drives) and vertically (by replacing smaller drives with larger drives).
x-raid2 is just version 2. in some firmware although ver 2 is employed the term x-raid is still used to distinguish from flexi raid
x-raid is default u dont have to select when set up, and if u have 4 disk or more the system will default to raid 6
of course u can turn to flexi raid by destroying the volume and choose other raid levels or no raid such as jbod
cpu8088
Oct 23, 2015Virtuoso
radioguru6613
Oct 23, 2015Aspirant
OK so it's RAID-6 XRAID as you can imagine it's a bit confusing when you see both phrases on screen and no mention of XRAID2 whatsoever.
Miguel
