Sandshark
Jan 25, 2023Sensei
ZeroTier as a ReadyCloud replacement.
Well, a big part of a replacement, anyway. With ReadyCloud going away, a lot of folks are going to be looking for a replacement in order to have remote access to their ReadyNAS, I have been using...
Sandshark
Jan 26, 2023Sensei
No, that should have worked. The system on which I recently installed it does not have KernelPlus, so that could be a difference. It was actually a legacy NAS converted to OS6, but that shouldn't make a difference. You can download the 1.4.0 .deb and try to install that.
XtheUnknown
Jan 27, 2023Apprentice
Actually, I installed KernelPlus in the hope that would fix the dependencies (it didn't).
So, I downloaded the .deb files for both x64 and ARM from:
https://download.zerotier.com/RELEASES/1.4.0/dist/debian/jessie/pool/main/z/zerotier-one/
Installed them via the Apps tab
Turned on SSH
Entered the two zerotier-cli commands as per your first post (having already created a zerotier one account and network)
Turned off SSH
...and job done. Thanks.
Although, given the active user community despite the sheer contempt shown by Netgear for its network storage customers, I'm sure other options/improvements will emerge over the next few months.
Am I correct in assuming that I will need to re-install after any update (6.10.9?) to OS6? - Removing ReadyCLOUD will make quite a few settings in the UI redundant, and I wonder whether Netgear will be bothered to tidy things up to remove these.
- SandsharkJan 27, 2023Sensei
It should not be necessary to re-install after an OS update unless a dependency is broken. Given that Netgear seems to be going out of the NAS market, I wouldn't really expect any update from them that does so.
I probably did an apt-get update (note NOT upgrade) at some point prior to running the script. I'm not sure why that would cause it to install an earlier (and working) version than it did for you.
- LeventhFeb 04, 2023ApprenticeI truly agree with your thoughts about sheering contempt shown by Netgear for its network storage customers and It’s going on for a long time.
- DuckSoupNAS1Jul 23, 2023Aspirant
You certainly have had better luck than I!!!
Just upgraded to 6.10.9 as many posts referred to problems with .8!
I have also downloaded the .deb files from the location below and tried to upload and install via the APPS tab but the amd64.deb failed with a "architecture mismatch" message, the amdhf.deb loaded 3 of 6 pkgs and then failed and the amdel.deb failed after trying to load 1 of 2 pkgs.
Starting to think this is an exercise in futility!
Doug
- StephenBJul 23, 2023Guru - Experienced User
You must have an arm-based ReadyNAS. What model?
Did you apply the patches need to get apt-get to work? They are changes in
- /etc/apt/sources.list
- /etc/apt/apt.conf
Hi, it's an RN102 running 10.6.9, so yes it's an ARM system.
I expected the amd.deb to fail, but I also attempted to Upload...
zerotier-one_1.4.0_armel.deb
zerotier-one_1.4.0_armhf.deb
zerotier-one_1.4.0_arm64.deb
The update process started but failed part way through on each of them.
I used the sources.list and apt.conf suggested by Sandshark
Doug
