Sandshark
Jan 25, 2023Sensei
ZeroTier as a ReadyCloud replacement.
Well, a big part of a replacement, anyway. With ReadyCloud going away, a lot of folks are going to be looking for a replacement in order to have remote access to their ReadyNAS, I have been using...
Sandshark
Apr 12, 2023Sensei
The error is telling you you need iprout2. Unfortunately, Debian Jessie is no longer available from the standard sources, so apt can't download it. You can find a solution here: How-I-got-apt-update-and-install-to-work-with-Debian-Jessie . Or, you can download the .deb package from one of the Debian archives and install it locally as you did zerotier. You want iproute2_3.16.0-2_armhf.deb, which you can get from https://archive.kernel.org/debian-archive/debian/pool/main/i/iproute2/
Note to others: If you have an Intel based NAS, you obviously need the AMD64 version.
Google Translate:
El error te dice que necesitas iprout2. Desafortunadamente, Debian Jessie ya no está disponible en las fuentes estándar. Puede encontrar una solución aquí: How-I-got-apt-update-and-install-to-work-with-Debian-Jessie . O bien, puede descargar el paquete .deb de uno de los archivos de Debian e instalarlo como lo hizo con zerotier. Desea iproute2_3.16.0-2_armhf.deb, que puede obtener de https://archive.kernel.org/debian-archive/debian/pool/main/i/iproute2/.
Nota para los demás: si tiene un NAS basado en Intel, obviamente necesita la versión AMD64.
Sandshark
Apr 12, 2023Sensei
BTW, there is an armhf version of ZeroTier available that will also work on an ARM based OS6 ReadyNAS. armel is 32-bit and armhf is 64-bit. Probably doesn't much.
- SandsharkApr 12, 2023Sensei
Well, maybe there is a reason. If you go with the armhf version, you can install 1.6.0.
