Sandshark
Jan 25, 2023Sensei
ZeroTier as a ReadyCloud replacement.
Well, a big part of a replacement, anyway. With ReadyCloud going away, a lot of folks are going to be looking for a replacement in order to have remote access to their ReadyNAS, I have been using...
SS4098
Jun 07, 2023Aspirant
Thanks. I think the web interface just doesn't update that data very often at all. Disconnect/reconnect didn't change it. I also removed the identity files to get a new device ID and now it's showing 0.0.0, so whatever.
tigerten
Jun 07, 2023Luminary
You may have installed two copies. Believe they installed in two different directories. So not an upgrade. Uninstall the old version first.
- SS4098Jun 08, 2023Aspirant
I ran both apt list --installed and dpkg -l earlier this morning. They returned only one installed zerotier at 1.6.6. I was going to reinstall anyway but I got pulled away for a while. When I got back ZT web interface had updated and is now showing 1.6.6 for both my local NAS which I changed device IDs on and my remote NAS which I was limited to only upgrading so I didn't lose connection. Thanks for helping me verify things.
- SandsharkJun 08, 2023Sensei
I'm assuming you updated a version other than a ReadyNAS-specific one (nt1 version) since I don't believe there ever was a ReadyNAS-specific V1.2.12. Because the ReadyNAS version installs in /apps instead of the usual place for Linux, updating from it to a standard release is a bad idea. Looks like all is well for you, but I'm adding this for the benefit of others.
