Sandshark
Jan 25, 2023Sensei
ZeroTier as a ReadyCloud replacement.
Well, a big part of a replacement, anyway. With ReadyCloud going away, a lot of folks are going to be looking for a replacement in order to have remote access to their ReadyNAS, I have been using...
OldSchoolGuy
Jul 08, 2023Aspirant
Hi Again, Got brave today and upgraded the ram, now I am going to make it as resolved, and will put what I did to resolve it on my post. Anywho, I want to install Zerotier on my ReadyNAS, I know that the Jessie thing is gone so, I’ve tried to manually download it, but I can’t access the folder cd/data/temp. Tried using apple, and Mac computers and they said no such file or directory. My Mac was using putty (obviously) and my windows computer was running Putty. Also tried using ExtraPutty, same result. I am logging in as Root. I am on the latest firmware for the ReadyNAS 314 firmware, 6.10.9. Need some help, I know that I am doing basically all correct but cannot access the files via SSH.
Sandshark
Jul 09, 2023Sensei
hat would be because there is no such directory. Assuming your data volume is named data. then I assume you are trying to cd into directory /data/temp, so you are leaving out a space.
- StephenBJul 09, 2023Guru - Experienced User
Is temp a share that you've created?
- OldSchoolGuyJul 09, 2023Aspirant
Sorry to sound noobish but I am quite confused on what to type in now to install the app manually. What am I going to type in? Thanks again for your guys quick response but I am confused on what to type in now.
- SandsharkJul 09, 2023Sensei
This is now a complex process due to Debian Jessie no longer being hosted on the normal update servers.
how am I going to manually install the app now since the cd/data/temp doesn’t work anymore…. (Or I’m not sure if that’s where the folders are stored).
