jabenedicic's avatar
Jan 12, 2023
Status:
New Idea
Enable DHCP Snooping features in Insight Management
It would be really useful to be able to configure DHCP Snooping features within the web or mobile interfaces. Certain scenarios involving DHCP just make using managed mode impossible.
6 Comments
  • schumaku's avatar
    schumaku
    FVBE wrote:
    I still can't find this feature in Insight ...
    Any news when the DHCP snooping feature will be available ?
    Both the APP and the Insight Web does support the DHCP snooping configuration.
    This and several more features depend on the Insight Manageable switch generation and the effective products release date.
    While Netgear continues to provide bugfix releases for some time, features are set with the product specification time - around the model first market appearance.   New Insight features are not automatically backported to older or earlier models.
  • BrianL's avatar
    BrianL
    NETGEAR Moderator
    Hi FVBE,
    Welcome to the community!
    I haven't heard anything about it yet being added /or implemented in Insight. Can you submit a feature request here instead?
    Kind regards,
    BrianL
  • FURRYe38's avatar
    If you don't see it anywhere since this was first poste, may not be implemented. Something to contact NG about directly thru support.
  • I still can't find this feature in Insight ...
  • Yes that would be correct. Unless I’m understanding something else incorrectly.
    I have the Orbi RBKE963 WiFi 6E router and AP’s. This is used as my internet router and DHCP/DNS. I am moving to pfSense for this but haven’t had the chance to try this out yet, assume it will be the same.
    When I added some MS510TXM switches to my lab network, out of the box I set them up with the Insight managed mode. Using them like this no devices on my network would receive DHCP addresses. I couldn’t find any specific helper configuration in the Insight portal.
    I ended up reconfiguring for stand-alone mode and had to enable this snooping feature in order for devices to get DHCP addresses.
    That’s why I put this suggestion forward. However if there is another way to achieve the same results I’m happy to give that a try too.
