Dimitri_vanes's avatar
Feb 04, 2024
Status:
New Idea
fans noise GS728TPv2
The fan speed is fixed to 4000 RPM, can this be changed to smart as the switch is not installed in a server cabinet.
the tempeture is als stable. i think it should ajust itself according toe what the switch needs for cooling.
I would like to know if this is possible.
2 Comments
  • Hi,
    I have the same issue with the MS324TXUP its WAAAAAAAY too loud. Very annoying when used in residential buildings
  • BrianL's avatar
    BrianL
    NETGEAR Moderator
    Hi Dimitri_vanes,
    A quite similar thread has been posted before (you can see it here). Let me check with our Switch Engineers if this feature request has been logged.
    Kind regards,
