BowQtr
Mar 12, 2021Follower
Status:
New Idea
Insight Clients module - add more wireless fields to help investigations
In the client section of the Insight App, it would be useful to see additional information against each device, for instance, which channel frequency are they using 2.4 to 5Ghz, what channel are they...
schumaku
Mar 12, 2021Guru - Experienced User
A good part of what you are looking for here is readily available on the Insight Web portal, including romaing history, security, channel, signal level, ...
