saurabhstar's avatar
saurabhstar
Follower
Oct 31, 2017
Status:
Unspecified
Feature Request- Alexa skill support for English India language as Echo devices launched in India
Feature Request: 1. Enable support for English India language in Netgear alexa skill so users from India could also use netgear routers with alexa as Echo devices are officially launched in India.
2. In the Netgear downloader, https links are not added and most of the websites are now switching to https links even for downloads.
8 Comments
Comments have been turned off for this idea
  • I've netgear x6 nighthawk 8000  router which is capable of Alexa. I also have Amazon echo plus, need NETGEAR skill in India. Can't utilise router to full capacity without Alexa skill.
  • JasonN's avatar
    JasonN
    NETGEAR Employee Retired
    Hi Everyone,
    Thank you for your suggestion on adding the Indian language to Skill as a feature. We will review the idea for consideration. :]
    - Jason N
  • i have orbi , but am not able to install the netgear skill , pls enable the skills
  • Its been one year since this post was added. Netgear please release alexa skill for Netgear in India.
  • I found the following website(searchsentences.com) has different response time if I open it at 7 in the morning vs 7 in the evening. Any specific cause. My hardware is  Netgear R6120-100INS AC1200 Dual-Band Wi-Fi Router. Does it has to be a hardware issue or the server side issue?
