Because of network topology it is often not possible to protect the router(s) device from internal (to the network) hacks or security compromises.
Passwords are a good start.
What would be a great addition and probably not too much development is to implement a password failure count and after so many failures refuse attampts for 30 minutes or so.
Make it a configuration option.
2 Comments
- AbhayBNETGEAR Employee RetiredStatus changed:UnspecifiedtoResolved
Routers already have a failure count of 3 after which you have to either factory reset the router or use password recovery.
- ElaineMNETGEAR Employee Retired
Thank you for that feedback.
Will go ahead and forward that to our engineering department.
