Netgear usb controll center does not work!!! When there will be an update for OSX El Captan????
37 Comments
- SenatorJonesFledgling
OMFG HOW CAN U BE SO F******* RETARDED SLOW?!?!??!?!?!!?!!!! SHOULD NEVER EVER HAVE BOUGHT NETGEARS **bleep**...
- PäddyNovice
i have the same problem: Update MAc to el capitan and since then no printer available. I expect a solution asap from Netgear!!
- marcworldNovice
Same problem here. It is infuriating. FWIW, I can connect to the printer that is attached to my router just fine. Even from my El Capitan Mac that shows this persistent and annoying "Installation is incomplete!" bug, I can actually still print fine.
NETGEAR WHEN YOU ARE GOING TO FIX THIS?
WHATEVER ANSWER YOU HAVE TO OFFER - IT'S NOT FAST ENOUGH.
- marcworldNovice
Note to others - On my Mac, even though the "NETGEAR USB Control Center" window shows no devices listed....If I just quit the app...then try and print something in a different app, like a web browser....my printer is still available in the regular Mac printers list.
still no update from Netgear huh
- padraigtxNovice
Merry Christmas Netgear....yes, it is December.
El Capitan was released in September and we are still waiting for Netgear to update its software to be compatible. Every other application on my Mac is compatible...except Netgear USB Control Center. When....oh when???
- goldsoulAspirant
Netgear you should fire all of your computer science majors if they still haven't figuired out how to make this program compatible with osx el capitan. I'm probably never gonna buy another product from your company because of this! - bhart777Fledgling
Wow. I bought two R8000's and the don't do what they say they will. I have a home business and I need readyshare to work!
- TheGoldenMasterInitiate
Is there a way to get an email. or some sort of notification when there is an update? That would be definatley appreciated.
Jesse
