It would be great to have a wall mount bracket for the Orbi router. My previous two wifi routers mounted on the wall.
5 Comments
Comments have been turned off for this idea
- DarrenMSr. NETGEAR Moderator
Hello JBMN
I saw you post this in the Idea exchange board anyone else that sees this and wants the feature should go up vote the Idea I linked the thread below.
DarrenM
- William10aMaster
They also be in designer colors as well to fit in your home just content any metal elements in the colored finish. With a couple of mount holes in a plastic vented outer case. With a vacuum form machine and a wooden form with holes in it for the vacuum table a person cold make a holder.
I've had my Apple Airport mounted on the wall for years. I currently have the Orbi mounted using the mount used for the last generation of the Airport. Even though the hardware is not similarly shaped, the cables keep it on the mount (I'm using all 4 Ethernet ports on the router, so that gives it stability).
It would be nice to have a mount made specifically for the Orbi though!
- NETGEAR_TeamCommunity ManagerStatus changed:UnspecifiedtoNew Idea
- ekhalilMaster
I bought the following wallmonuts from Amazon and they are just perfect.
https://www.amazon.co.uk/gp/product/B0793LKH58/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
