- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk M1 mobile router not connecting to Xbox live
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk M1 mobile router not connecting to Xbox live
Hello aarfmann
You may need to do some port forwarding.
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Port forwarding doesn't solve the internet connection issue. I am not having NAT issue, the modem will simply not allow by xbox to connect to the internet.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Can you check what IP and gatway information the xbox is receiving? I'm assuming the xbox is set as a DHCP client
- Mark as New
- Bookmark
- Subscribe
- Permalink
have same problem Xbox connects to modem but not internet.
Has a solution been found ?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Connected by wi-fi..... there has to be a simple solution for this ... I just don't get it that Telstra & netgear sell incompatible stuff...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Can you provide any information , like the error xbox is giving and the ip configuration and gateway it is using? I've tested my M1 with my nephews xbox and no issue, didn't have to configure anything out of the ordinary. The only issue you may have is if you are behind a double NAT setup by your ISP, then you can still get out, but no one would be bale to connect back to you if you try running a server
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Have you tried setting the xbox network settings to automatic including setting the xbox DNS to automatic (under advanced settings)and also DHCP client.
In the modem under settings > router setup >DNS mode set to manual if you don't want to use Telstra DNS, and DNS server to 8.8.8.8 and under alternate DNS server 8.8.4.4 (these are googles DNS server addresses).
If you are getting NAT errors after that it is because Telstra use consumer grade NAT on mobile connections and not much you can do about it unless you have a business grade connection that provides a public IP.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
If it is only happening with the Wifi on the xbox. Then there is no need to make any changes to the modem. I'd delete the xbox wifi connection it currently uses to connect to the M1 and recreate it, make sure to set the xbox to DHCP client and everything to automatic. Also keep in mind that the M1 will turn off its wifi after a few minutes by default , so may be a issue for the xbox. That would mean it works initially though then stopped working.
- Mark as New
- Bookmark
- Subscribe
- Permalink
If the wifi turns off by default after a few minutes how do you change that ?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks I'll give it a go
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
No...... no answers.... Netgear does not care..... this is an ongoing thing with the M1.... time to go to another modem me thinks... the older ones were fine...
