Moussa854's avatar
Moussa854
Block adult and peer to peer on WAC510
I have an access point that is functioning as a router and AP and would like to block adult and peer to peer sharing websites. OpenDNS did not work.
- Anyone had luck doing so?
Best
  • RaghuHR's avatar
    RaghuHR
    Nov 29, 2018
    Moussa854
    Please refer the attached write-up and config details. Share your feedback once follow the procedures.
    Thanks,
    Raghu
  • schumaku's avatar
    schumaku
    OpenDNS would work, permitting the Web UI would allow overriding the DNS servers for the router/Internet config.- as discussed in the other thread.
      • schumaku's avatar
        schumaku
        RaghuHR wrote:
        Have you tried WAN interface as static and configuring manually DNS server field?
        ...a rather useless advise, considering most Internet connections are supplying dynamic configuration (even for these with reserved/"fixed" IPv4 addresses.
        Gee, different from many other routers which allow dynamic WAN but override DNS the WAC510 does not. One of the reasons - among lots of strange L2 noise I had stopped testing it as a router, remember RaghuHR?
        No other way than change the UI config options....
    • Moussa854's avatar
      Moussa854
      I was going to try the web interface again but had issues with my computer. I will fix my computer and post teh result here.
      • RaghuHR's avatar
        RaghuHR
        NETGEAR Expert
        Moussa854
        Thanks,
        Raghu
ProSupport for Business
