Janelyn
Aug 29, 2021Follower
Looking for outdoor ap that connects by Ethernet cable.
I have an Orbi system inside my house now. I want to get better coverage outside that does not have to be another satalite. I'd like recommendation.
Criteria: outdoor, attached to router by Ethernet cable then wireless outward, not another wireless extender.
I just bought a AX1800 AP for an outbuilding, but need something similar for outdoors
I appreciate and advice.
1 Reply
Netgear has the was610y that is an outdoor rated access point. Its ran over POE connection.
https://www.netgear.com/business/wifi/access-points/wax610y/
You also have the option of the netgear airbridge (wbc502). Its an outdoor rated point to point device that has an access point mode.
https://www.netgear.com/business/wifi/wireless-bridges/wbc502/
That along the lines of what you're looking for?
