jpridx
Mar 19, 2019Tutor
Model WAC 104 (Access Point) can't access login page
Hello! I just purchased a Netgear WAC 104 Access Point unit, and it appears as though there's no website available to connect to in order to get this unit operating. I've tried http://www.aplogin.net ad well as 192.168.0.100, and all I get is a website that's under construction with absolutely no login connection available. Needless to say, this is becoming a rather frustrating experience. Thanks in advance!
The problem has been resolved! It seems that Netgear has slipped a few notches in recent years. The installation manual was worthless.
- jpridxTutor
I guess my question is this: Is the website temporarily unavailable? Or has it simply been abandonded not to be used any longer? If the latter is the case, it appears that I just blew my money on a unit that can't possibly be used as an access point.
- jpridxTutor
The default IP maybe if you have a directly connection with a PC with out it being connected to a router. The APs IP address will be what ever is seen on the routers connected clients list that the WAP gets from the router.
