crflores's avatar
crflores
NetGear AP WAX214 - AX 1800 Cannot Connect Android Device
I'm Receiving the following Error While Trying to Connect to the AP an Android 11 HK1 MAX TV Box (mac address 5c:f8:a1:a1:e9:d7),   I was able to connect to a old LinkSys Router without Issues but after upgrading to the Netgear, I can connect all other devices for the exception of this particular device, I have Change a few settings on the router but I'm still receiving the same error.
Jan 26 21:54:02 WAX214 daemon.info hostapd: ath1: STA 5c:f8:a1:a1:e9:d7 WPA: sending 3/4 msg of 4-Way Handshake
Jan 26 21:54:02 WAX214 daemon.info hostapd: ath1: STA 5c:f8:a1:a1:e9:d7 WPA: sending 1/4 msg of 4-Way Handshake
Jan 26 21:54:02 WAX214 daemon.info hostapd: ath1: STA 5c:f8:a1:a1:e9:d7 WPA: received EAPOL-Key frame (4/4 Pairwise)
Jan 26 21:54:02 WAX214 daemon.info hostapd: ath1: STA 5c:f8:a1:a1:e9:d7 WPA: received EAPOL-Key frame (2/4 Pairwise)
Jan 26 21:54:02 WAX214 daemon.info hostapd: ath1: STA 5c:f8:a1:a1:e9:d7 WPA: pairwise key handshake completed (RSN)
Jan 26 21:54:02 WAX214 daemon.info hostapd: ath1: STA 5c:f8:a1:a1:e9:d7 IEEE 802.11: authenticated
Jan 26 21:54:02 WAX214 daemon.info hostapd: ath1: STA 5c:f8:a1:a1:e9:d7 IEEE 802.11: associated (aid 1)
Jan 26 21:51:47 WAX214 daemon.info hostapd: ath1: STA 5c:f8:a1:a1:e9:d7 IEEE 802.11: disassociated
Jan 26 21:51:46 WAX214 daemon.info hostapd: ath1: STA 5c:f8:a1:a1:e9:d7 IEEE 802.11: authenticated
Jan 26 21:51:39 WAX214 daemon.info hostapd: ath1: STA 5c:f8:a1:a1:e9:d7 WPA: sending 3/4 msg of 4-Way Handshake
Jan 26 21:51:39 WAX214 daemon.info hostapd: ath1: STA 5c:f8:a1:a1:e9:d7 WPA: sending 1/4 msg of 4-Way Handshake
Jan 26 21:51:39 WAX214 daemon.info hostapd: ath1: STA 5c:f8:a1:a1:e9:d7 WPA: received EAPOL-Key frame (4/4 Pairwise)
Jan 26 21:51:39 WAX214 daemon.info hostapd: ath1: STA 5c:f8:a1:a1:e9:d7 WPA: received EAPOL-Key frame (2/4 Pairwise)
Jan 26 21:51:39 WAX214 daemon.info hostapd: ath1: STA 5c:f8:a1:a1:e9:d7 WPA: pairwise key handshake completed (RSN)
Jan 26 21:51:39 WAX214 daemon.info hostapd: ath1: STA 5c:f8:a1:a1:e9:d7 IEEE 802.11: authenticated
Jan 26 21:51:39 WAX214 daemon.info hostapd: ath1: STA 5c:f8:a1:a1:e9:d7 IEEE 802.11: associated (aid 1)
Jan 26 21:51:23 WAX214 daemon.info hostapd: ath1: STA 5c:f8:a1:a1:e9:d7 IEEE 802.11: disassociated
Jan 26 21:51:22 WAX214 daemon.info hostapd: ath1: STA 5c:f8:a1:a1:e9:d7 IEEE 802.11: authenticated
Jan 26 21:48:20 WAX214 daemon.info hostapd: ath1: STA 5c:f8:a1:a1:e9:d7 WPA: sending 3/4 msg of 4-Way Handshake
Jan 26 21:48:20 WAX214 daemon.info hostapd: ath1: STA 5c:f8:a1:a1:e9:d7 WPA: sending 1/4 msg of 4-Way Handshake
Jan 26 21:48:20 WAX214 daemon.info hostapd: ath1: STA 5c:f8:a1:a1:e9:d7 WPA: received EAPOL-Key frame (4/4 Pairwise)
Jan 26 21:48:20 WAX214 daemon.info hostapd: ath1: STA 5c:f8:a1:a1:e9:d7 WPA: received EAPOL-Key frame (2/4 Pairwise)
Jan 26 21:48:20 WAX214 daemon.info hostapd: ath1: STA 5c:f8:a1:a1:e9:d7 WPA: pairwise key handshake completed (RSN)
Jan 26 21:48:20 WAX214 daemon.info hostapd: ath1: STA 5c:f8:a1:a1:e9:d7 IEEE 802.11: authenticated
Jan 26 21:48:20 WAX214 daemon.info hostapd: ath1: STA 5c:f8:a1:a1:e9:d7 IEEE 802.11: associated (aid 1)
Jan 26 21:45:41 WAX214 daemon.info hostapd: ath1: STA 5c:f8:a1:a1:e9:d7 IEEE 802.11: disassociated
Jan 26 21:45:40 WAX214 daemon.info hostapd: ath1: STA 5c:f8:a1:a1:e9:d7 IEEE 802.11: authenticated
Jan 26 21:43:00 WAX214 daemon.info hostapd: ath1: STA 5c:f8:a1:a1:e9:d7 WPA: sending 3/4 msg of 4-Way Handshake
Jan 26 21:43:00 WAX214 daemon.info hostapd: ath1: STA 5c:f8:a1:a1:e9:d7 WPA: sending 1/4 msg of 4-Way Handshake
Jan 26 21:43:00 WAX214 daemon.info hostapd: ath1: STA 5c:f8:a1:a1:e9:d7 WPA: received EAPOL-Key frame (4/4 Pairwise)
Jan 26 21:43:00 WAX214 daemon.info hostapd: ath1: STA 5c:f8:a1:a1:e9:d7 WPA: received EAPOL-Key frame (2/4 Pairwise)
Jan 26 21:43:00 WAX214 daemon.info hostapd: ath1: STA 5c:f8:a1:a1:e9:d7 WPA: pairwise key handshake completed (RSN)
Jan 26 21:43:00 WAX214 daemon.info hostapd: ath1: STA 5c:f8:a1:a1:e9:d7 IEEE 802.11: authenticated
Jan 26 21:43:00 WAX214 daemon.info hostapd: ath1: STA 5c:f8:a1:a1:e9:d7 IEEE 802.11: associated (aid 1)
The Configuration of the Router is this one.
can you please help me what else can I do.
      • plemans's avatar
        what channel are you using for 2.4ghz?
        Have you tried changing?
        What's the android device giving you for an error?
ProSupport for Business
