- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
POE for WAC510
- Mark as New
- Bookmark
- Subscribe
- Permalink
Can NETGEAR GS305P v2 power the WAC510 Router?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
It should. The WAC510 only needs a 802.3af power supply that can supply 9.3 watts.
The GS305Pv2 is a 802.3af power supply that can max put out 63 watts between all its ports with up to 30 watt on a single port max. (according to its spec sheet)
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: POE for WAC510
thank you for your reply.
I already ordered it, can't wait to try it!
I already bought 2 PoE switches(non NEATGEAR) and they don't power the WAC510.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: POE for WAC510
Good luck!
In theory it should work. We'll see what reality says 🙂
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: POE for WAC510
YES!! it's working!!thank you very much for your support.
- Mark as New
- Bookmark
- Subscribe
- Permalink
