Arsenio
May 23, 2022Tutor
POE for WAC510
Can NETGEAR GS305P v2 power the WAC510 Router?
- May 23, 2022
It should. The WAC510 only needs a 802.3af power supply that can supply 9.3 watts.
The GS305Pv2 is a 802.3af power supply that can max put out 63 watts between all its ports with up to 30 watt on a single port max. (according to its spec sheet)
May 23, 2022Guru - Experienced User
Arsenio
May 24, 2022Tutor
thank you for your reply.
I already ordered it, can't wait to try it!
I already bought 2 PoE switches(non NEATGEAR) and they don't power the WAC510.
