Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Reply
Power requirements for WAX214v2
Southst
What are the minimum power requirements when using a Poe+ injector with the wax214v2 access point? Approximately 50’ run from the Poe injector to the wap.
 Thanks.
Message 1 of 4
microchip8
Master
Re: Power requirements for WAX214v2
Can't find or Google for documentation???
Go to NETGEAR's site, go to Support, enter your model number, get PDF, read!
Routing: NETGEAR RAX43 - Firmware: v1.0.15.128 (1 Gbps down, 40 Mbps up)
Switching: 2x NETGEAR 8-ports (GS108v4) / 1x NETGEAR 16-ports (GS116v2) / 2x NETGEAR PL1000v2
Desktop: AMD Ryzen 9 5900X - Server: Intel Core i7-7700K - NAS: Intel Pentium G4400, 20 TB
Message 2 of 4
Southst
That would have been an extremely helpful response if the documentation for that wap, which I had previously read, actually specified minimum power requirements. Unfortunately, as far as I can tell, it doesn’t, so it is not.
Message 3 of 4
schumaku
Guru
It's printed about 100 times (wild guess) in the WAX214v2 User Manual
PoE+ (802.3at) switch is required, however a PoE (803.2.af) switch might be sufficient if the the AP’s 2.4 GHz radio works with reduced transmit power. Certainly not something I'd see as a normal suggested operation status,
The minimums are set by the IEEE standardization - this depends on the possible length of the installation. Again not something you should consider as an installation standard, unless you are to cheap to invest in industry standard PoE+ switches.
Strictly stay with the IEEE Standards, like 802.3at or bust. Can't be easier.
Can't wait for a new post where somebody comes and lists cable quality and length, some voltage and amps details, in-span and out-span blah, and so on. Far to many power injectors in the market, for proprietary junk like so called passive PoE devices.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 415 views
  • 1 kudo
  • 3 in conversation
Announcements
