Reply
WAC510 in AP Mode must be connected to WAN instead of LAN for VLAN ID to work
twoods
Apprentice
In case this is helpful for anyone else, I discovered while using the WAC510 in Access Port mode that changing the SSID VLAN ID only works when the network is connected to the WAN port instead of the LAN port. The manual does say with AP mode to connect to the WAN port but I had it unintentionally connected to the LAN port.
Model: WAC510|Insight Managed Smart Cloud Wireless Access Point
Message 1 of 2
DaneA
NETGEAR Moderator
Re: WAC510 in AP Mode must be connected to WAN instead of LAN for VLAN ID to work
@twoods,
Thank you for sharing your discovery here in the community.  The WAC510 users here in the community will now be aware what will happen if in case the LAN port  of the WAC510 is being used instead of the WAN port while the WAC510 is set to AP mode.
DaneA
NETGEAR Community Team
Message 2 of 2
Discussion stats
  • 1 reply
  • 1756 views
  • 4 kudos
  • 2 in conversation
Announcements
