frenchfry66
Dec 08, 2023Follower
WAX220 - Access Point as Central Unit in All-Wireless Network
Hello,
I'm thinking of buying a WAX220 AP to set up a lab with many devices. I don't need an Internet or an Ethernet connection to a router, I just want a local private all-wireles network for many devices. Is this possible
I've read the manual and it looks like after powering on (with an adapter) one could first connect to the Managed Wifi to setup the AP - changing the password, creating the first User Wifi, setting up the DHCP range - and then simply connecting my lab devices to the new User Wifi, assuming DHCP works for them.
What do you think?
Thanks
1 Reply
Keep in mind the Guest network with its basic DHCP capability is an "in-box" NATed guest network, there is no transparent L2 bridge connection between the wireless guest network and the wireless clients. I guess operating the WAX220 with a static IP might be feasible. The complete guest network which logically and physically exists in the WAX220 only. Tend to suggest using the plain AP mode, and include a device serving DHCP for the physical network for a minimalist test lab.
