astralblue's avatar
astralblue
WAX610 V9.5.1.20 – WAX6XX SNMP MIB inaccessible, walk skips the enterprises tree
Greetings,
I have upgraded my 3 WAX610 APs to V9.5.1.20 today, and as the release notes say, the SNMP function with non-default community strings has been restored, but partially: It seems that the WAX6XX MIB tree (.1.3.6.1.4.1.4526.100.7.14) is inaccessible.  In fact, there seems to be nothing under the enterprise (.1.3.6.1.4.1) tree.  See the transcript below:
$ snmpwalk -v2c -c<redacted> -On 192.168.1.9 WAX6XX::wax6xx
.1.3.6.1.4.1.4526.100.7.14 = No Such Object available on this agent at this OID $ snmpget -v2c -c<redacted> -On 192.168.1.9 WAX6XX::sysVersion.0
.1.3.6.1.4.1.4526.100.7.14.1.3.0 = No Such Object available on this agent at this OID
$ snmpwalk -v2c -c<redacted> -On 192.168.1.9 SNMPv2-SMI::enterprises
.1.3.6.1.4.1 = No Such Object available on this agent at this OID
Walking standard tree is fine, but it doesn't include the WAX6XX MIB.  Note how the walk jumps from .1.3.6.1.2 to .1.3.6.1.6, skipping the entire enterprise (.1.3.6.1.4.1) tree:
$ snmpbulkwalk -v2c -c<redacted> -On 192.168.1.9 SNMPv2-SMI::internet | grep -A1 '^\.1\.3\.6\.1\.2' | tail -2
.1.3.6.1.2.1.55.1.5.1.10.123 = INTEGER: 1
.1.3.6.1.6.3.1.1.6.1.0 = INTEGER: 262836920
My APs are standalone (not cloud-managed).  What can I do to access the WAX6XX MIB?
  • schumaku's avatar
    schumaku
    Can't get access to the NTGR private MIB on the WAX610 or 620 (no 630 to test) V9.5.1.20, too. Suspect bug. RaghuHR please.
      • schumaku's avatar
        schumaku
        RaghuHR wrote:
        Currently enterprise MIBs are not supported.
        This is a little bit odd, consideing explicitly these private MIB are made available along with the current firmware releases for the WAX610/610Y/620 and the WAX630...
        -- Specification.
        -- Status: Release
        -- Version: 9.0
        -- Internal Source Code Version:9.0.0.46
        -- Date: 1 Aug 2020
        -- History :
        --  1.0 : Initial Version
        --  9.0 :  Updated to MIBs to show once are deprecated.Deprecated mibs will be obeslete in next release.
        	WAX6XX DEFINITIONS ::= BEGIN
        		IMPORTS
        			OBJECT-GROUP
        				FROM SNMPv2-CONF
        			enterprises, IpAddress,Unsigned32, OBJECT-TYPE, MODULE-IDENTITY, Counter32, Counter64, NOTIFICATION-TYPE, TimeTicks
        				FROM SNMPv2-SMI
        			DisplayString, RowStatus, TruthValue, MacAddress
        				FROM SNMPv2-TC;
        -- *  MODULE IDENTITY
        		wax6xx MODULE-IDENTITY
                                LAST-UPDATED "202008010000Z"            -- 01 08, 2020 at 12:00 GMT
                                ORGANIZATION
                                       "NETGEAR Inc."
        			CONTACT-INFO
                                       "350 East Pumeria Drive
                                       San Jose, California 95134
                                       Phone: (408) 907-8000
                                       Fax: (408) 907-8097
                                       Web Site: http://www.netgear.com"
        			DESCRIPTION
        				"The MIB module for 802.11a/b/g/n/ac Enterprise WiFi AP.
        				iso(1).org(3).dod(6).internet(1).private(4).
        				enterprises(1).netgear(4526).productID(100).accesspoint(7).wax6xx(14)"
        			::= { accesspoint 14 }
        -- Node definitions
        -- The Enterprises Number
        		-- 1.3.6.1.4.1.4526
        		netgear OBJECT IDENTIFIER ::= { enterprises 4526 }
                        -- 1.3.6.1.4.1.4526.100
                        productID  OBJECT IDENTIFIER ::= { netgear 100 }
        		-- 1.3.6.1.4.1.4526.100.7
        		accesspoint OBJECT IDENTIFIER ::= { productID 7 }
        --   Wireless LAN Access Point ......
  • Hello,
    does anyone have an update to this topic?
    I have some WAX610, WAX610Y and WAX620 and want to access the MiB.
    I want to monitor some status like stationlisttable but i dont even get apName or anything.
    With every Firmware Version is also a MiB File available in Download Center:
    Download Center | Support | NETGEAR (WAX610)
    MiB File is in Version 9.0 since ever for WAX6XX devices and did not change since initial release?
    Why is there a MiB file, when it does not work porperly?
    Do i have to do some special settings to get these values?
    Greets
    Tobias
ProSupport for Business
