Reply
WNDAP350 and WPA-PSK
zoummuoz
Follower
Hi all,
I have a wireless network consisting of 16 terminals WG302 (V1 and V2). Not finding the material to sell, I turned to the WNDAP350.
My network is WPA-PSK.
It appears that on my machine, firmware 2.1.2 WPA-PSK will not work.
Everything works in OPEN ... my pockets being old (70 machines symbol PPT88xx) I do not want to change. Paramete my network being over 90 posts, I have no desire to change the encryption ...
I contacted netgear support several times. I expect the firmaware 2.1.5.3 to solve my problem.
Are you aware of this concern? if yes how did you solved?
Thank's for reply.
Message 1 of 2
adit
Mentor
Re: WNDAP350 and WPA-PSK
When I beta tested this unit under 2.1.2 I didn't see the problem. Could be the scanners. Let us know how 2.1.5.3 fares.
Message 2 of 2
Discussion stats
  • 1 reply
  • 13268 views
  • 0 kudos
  • 2 in conversation
Announcements
