- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
C3000 ping issues
- Mark as New
- Bookmark
- Subscribe
- Permalink
C3000 ping issues
Recently, about every 20 minutes to an hour my ping will jump from around 30 to 600. If I restart the router/modem the ping will go back to normal, but not until then, so I know it is a problem with the C3000 and not something with my ISP. Also I get a large ping spike once around every 30 seconds where my ping will spike to 600 and then return again.
I had this router/modem since May and it has just recently started doing this. Any idea for a solution?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: C3000 ping issues
Hello sammckira
I would check all your cable lines and ethernet cords make sure those are good maybe swap them out. Also if you have a cable splitter connected to the modem try removing that see if ping issue stops happening.
DarrenM
