Orbi WiFi 7 RBE973
Reply
C3000
Insaneclownman
Follower
C3000
I recently changed internet companies and I can't get my modem to connect with devices.
Message 1 of 3
Guru
Re: C3000
Try a factory reset and setup from scratch on the modem.
Netgear has set up a community forum specifically for the Cable Modem products. Most of the people who watch that forum are more likely to have experience with Cable modems and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Cable-Modems-Routers/bd-p/home-cable-modems-routers
Thank you.
Message 2 of 3
Guru
Re: C3000
Who's your isp?
Did you check with them to see if was compatible with their service?
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 603 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
