Orbi WiFi 7 RBE973
Reply
C3000Dv2 won't bridge
fiddletwix
I recently came home to discover that my Cable Modem was no longer in bridge mode and had NAT enabled. I went to change the setting by unchecking the "Enable NAT" box but the change won't stick.  The cable modem remains in NAT mode.  I unplugged the cable modem and then reset it when I powered it back on.  I was still not able to disable NAT mode.   I am a TWC customer and the firmware is the correct version as per this page: http://kb.netgear.com/app/answers/detail/a_id/25477/~/current-firmware-version-for-netgear-cable-mod...
Any suggestions?
Model: N450 (CG3000Dv2)|N450 WiFi Cable Modem Router
Message 1 of 4
TheEther
Guru
Re: C3000Dv2 won't bridge
Did TWC supply you with the modem?  If so, check with TWC.  Maybe, just maybe, they have locked out bridge mode.
Message 2 of 4
fiddletwix
No, this is my own device but this did happen when they also made some change that forced an IP change. I had the same IP for about a year and then it changed along with bridged mode. Is there anyway to verify that config option is locked out? They have in the past acted like this is their modem and factory reset it before so I can believe they made the change.
Message 3 of 4
TheEther
Guru
I don't know of any other way to verify other than the GUI itself.  Can you try doing a factory reset?
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 3036 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
