- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
C3700-100NAS signal strength
- Mark as New
- Bookmark
- Subscribe
- Permalink
I've noticed a significant decrease in signal strength within my new home to the point where I cannot even connect from the floor upstairs on the other side of my home. Total square footage of my home across 3 floors is only 1,576 sq ft. We had an acceptable signal when we first moved in but it has been slowly getting worse. I've already moved my router as far as I can but it still resides primarily on one side of our second floor within our townhome. This is also where the cable connection is, I'm unable to move it anywhere else. I'm looking for ideas to potentially help boost the signal, neither 2.4 or 5.0 GHz will connect.
There was an article about trying to use another router as a repeater (http://kb.netgear.com/app/answers/detail/a_id/20604/related/1). Unfortunately when I go into the admin panel of my router (C3700|N600) there is no "wireless repeating function" under the advanced wireless settings.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: C3700-100NAS signal strength
Hello harvela
Have you Tried to adjust the wireless channel in the wireless settings see if you get a better signal?
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have not tried different channels. What is different about the various channels that would make one better then another?
For my 5GHz connection I am using channel 153 and per the channel interference report this is the only one on that channel.
For 2.4GHz, it is channel 6 and only 4 networks in my area are using that channel.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello harvela
Changing channels helps reduce interference from other wifi signals and other home devices that can degrade the signal so you want your network on the least used channel.
DarrenM
