- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
C6220 Frequent Wifi disconnects and/or modem crashes
- Mark as New
- Bookmark
- Subscribe
- Permalink
Issue: Modem/Router goes offline frequently from twice a day to twice a week.
Firmware on the Modem/Router V1.02.11.
Xfinity Service package: Internet only, Performance Select 100mbs
The cable enters the house from outside and is directly connected to the Netgear C6220, no splitters.
No computer at the house. I have set up remote access on the modem/router and am accessing it from a different location.
There are only 6 devices connected to wifi: they are all "smart" sensors that run on the 2.4ghz band. Nothing is running on the 5g band, unless I go to the property and connect my phone to 5g.
When I connect to 5g, the speed is as expected.
I know when the modem/router goes down, because all my devices alert me via text & email, with a time stamp.
The time stamp of when they go down does not always match the timestamp in the logs on the modem/router.
I have remote access enabled on the modem/router, and when it "goes down" I attempt to access it via my computer, and am unable to do so until I log into my Xfinity.com account, and reboot the modem from the Xfinity interface.
I have never been at the property when it goes down, and so have not looked at the lights on the modem/router.
This is what I've done, in my attempts to fix this issue:
1) Unplugged the modem for 20 minutes, then plugged it back in and rebooted.
2) Cleaned the contacts and tightened them.
3) Tested the wifi using Ookla, M-Lab and Xfinity speed test
(at 6 feet away on the 2.4 band, it's fluctuates between 10 and 40 mbps download and 1 to 15 upload)
4) Tested the modem with a direct RJ45 connection (Download over 121, which is fine, I'm only paying for 100, upload is adaquate)
5) Changed the 2.4 channel to 11 (had less traffic), now it's got a lot of traffic, so I'm changing it to "auto"
6) Moved the modem to a position where it had more air circulating underneath it, as it seemed overly warm
I'm posting logs below. Stangely the logs do not reflect the same time of failure as my devices do. For example, all my devices went down on Feb 13, 2021 at 1:35 AM. The log shows the Modem/Router going down at 7:48 AM, which is actually the time when I reset it.
Also, note the difference in todays (2/13/2021) cable log, and the last time it went down, on 2/8/2021, five days ago.
Thanks for any help anyone can give.
2021-02-13, 07:50:45.0 | Warning (5) | MDD message timeout;CM-MAC=28:80:88:9a:7e:30;CMTS-MAC=00:01:5c:66:00:46;CM-QOS=1.1;CM-VER=3.0; |
2021-02-13, 07:48:37.0 | Critical (3) | Resetting the cable modem due to docsDevResetNow |
2021-02-03, 17:12:39.0 | Critical (3) | Resetting the cable modem due to docsDevResetNow |
2021-02-03, 17:06:32.0 | Critical (3) | Resetting the cable modem due to docsDevResetNow |
2021-02-02, 08:56:58.0 | Critical (3) | Resetting the cable modem due to docsDevResetNow |
2021-02-02, 07:47:17.0 | Critical (3) | Resetting the cable modem due to docsDevResetNow |
2021-01-27, 10:43:58.0 | Critical (3) | Resetting the cable modem due to docsDevResetNow |
2021-01-21, 20:21:12.0 | Critical (3) | Resetting the cable modem due to docsDevResetNow |
2021-01-16, 16:04:55.0 | Critical (3) | Resetting the cable modem due to docsDevResetNow |
2021-01-11, 18:40:13.0 | Critical (3) | Resetting the cable modem due to docsDevResetNow |
2021-01-05, 14:55:40.0 | Critical (3) | Resetting the cable modem due to docsDevResetNow |
2021-01-05, 09:04:39.0 | Critical (3) | Resetting the cable modem due to docsDevResetNow |
2020-12-31, 08:07:39.0 | Critical (3) | Resetting the cable modem due to docsDevResetNow |
2020-12-28, 07:33:49.0 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=28:80:88:9a:7e:30;CMTS-MAC=00:01:5c:66:00:46;CM-QOS=1.1;CM-VER=3.0; |
2020-12-25, 11:12:53.0 | Critical (3) | Resetting the cable modem due to docsDevResetNow |
2020-12-24, 19:32:21.0 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=28:80:88:9a:7e:30;CMTS-MAC=00:01:5c:66:00:46;CM-QOS=1.1;CM-VER=3.0; |
2020-12-19, 07:25:59.0 | Critical (3) | Resetting the cable modem due to docsDevResetNow |
Time Not Established | Notice (6) | Honoring MDD; IP provisioning mode = IPv6 |
Time Not Established | Critical (3) | No Ranging Response received - T3 time-out;CM-MAC=28:80:88:9a:7e:30;CMTS-MAC=00:01:5c:66:00:46;CM-QOS=1.0;CM-VER=3.0; |
Cable Log from today 2/13/2021
Frequency start Value | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect. | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Startup Procedure | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Downstream Bonded Channels | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Upstream Bonded Channels | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Current System Time: Sat Feb 13 09:39:43 2021 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
System Up Time: 0 days 1:50:30 |
Log from crash 5 days ago, 2/8/2021
Current System Time: Mon Feb 08 14:21:24 2021 |
System Up Time: 0 days 0:27:52 |
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: C6220 Frequent Wifi disconnects and/or modem crashes
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Natedeeeez No one has ever even looked at, much less replied to my inquiry. There are, in fact, quite a lot of people, in the past who have had this exact problem. Somehow they got responses, but not me, apparently
I gave up on ever getting any help from Netgear and my ISP, which is Xfinity.
Instead, what I've done to solve the issue was to purchased a TP Link router. Then I went into the settings on the Netgear Modem/Router and turned the Wifi function OFF and simply am using the Netgear product as a modem, and the TP link as the router.
So far at least (it's been over a week) I have NOT lost wifi. Before I did this, the Netgear Modem/Router was dropping the Wifi every few days, sometimes twice a day. So, this might have solved the issue. This is the second Netgear combination Modem/Router that has had frequent failures, the other one was a NETGEAR CM1150V that I ended up returning to Netgear, because of the constant crashes. Personally, I won't buy another combination modem/router, especially one from Netgear. Good luck to you.
My advice, try any other brand than Netgear. They clearly have quality control issues now, and abysmal support, which is a shame, because for 25 years, I've only bought Netgear.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Mod...
