Orbi WiFi 7 RBE973
Reply
C6300 Dropping wifi connection suddenlt
gocker102293
I can't seem to find a straight answer on here so I feel like asking again. I have an AC1750 modem/router that has been working fine for the past 8 months or so. In the past few days, it has been suddenly dropping WiFi and won't correct itself without being unplugged or rebooted. If I plug in with an Ethernet cable, the internet will always work. I also know at some point the wireless radios got turned off for both 2.4/5 frequencies. I've tried everything I can think of and conducted a factory reset. I've also verified with my ISP that nothing is malfunctioning on their end. Any ideas?
Model: C6300BD-1CXNAS|Docsis 3.0 AC1750 Cable Modem Router
Message 1 of 10
Accepted Solutions
Smith3993
Guide
Re: C6300 Dropping wifi connection suddenlt
I fought this problem for months and finally discovered that the problem for me was the PSP (Power Save Polling) feature of my Windows laptop, which is not supported by this router. In short, when the laptop's wifi adapter would "sleep" in power saving mode, it would basically block all connections to the router, and I would lose all connections (phones etc.) on the 2.5G channel that the laptop was using. To fix this, go to your Device Manager, click on Network Adapters, right click on wireless adapter, click properties, click Power Management, and UNselect "Allow the computer to turn off this device to save power". Mine has worked flawlessly ever since doing this. Hope this helps.
Message 8 of 10
All Replies
z33k
I am having the same issue. Wireless network drops, but wired connections are fine. When I view the router settings everything shows to be operational. Turning on and off the wireless via the admin settings (advanced/advanced setup/wireless settings/enable radio) doesn't have any effect, neither does turning on/off the SSID.
The only thing that solves the issue is power cycling the router. It happens at random times, and is getting more frequent.
Model: C6300|AC1750 Cable Modem Router Docsis 3.0
Message 2 of 10
gocker102293
Yeah ours is up to multiple times per day now and I'm getting irritated with power cycling it so frequently. I tried using the Netgear Genie to detect a problem but because it has to be plugged in to the computer via Ethernet when it's not working, Netgear Genie thinks everything is working fine.
Message 3 of 10
DarrenM
Sr. NETGEAR Moderator
Can you post the logs of the modem or check and see if any issues are showing up when the wifi stops working?
DarrenM
Message 4 of 10
gocker102293
Here's the latest from the event log, but the failure occurred just now at 3:30 PM
Sep 12 2017 09:12:03Warning (5)MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1
Sep 11 2017 18:03:23Critical (3)No Ranging Response received - T3 time-out
Sep 11 2017 12:33:32Warning (5)MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1
Time Not EstablishedCritical (3)No Ranging Response received - T3 time-out
Time Not EstablishedCritical (3)Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out
Time Not EstablishedCritical (3)TFTP Request Retries exceeded, CM unable to register
Time Not EstablishedCritical (3)TFTP failed - Request sent - No Response
Time Not EstablishedWarning (5)ToD request sent - No Response received
Time Not EstablishedWarning (5)Lost MDD Timeout
Time Not EstablishedCritical (3)SYNC Timing Synchronization failure - Loss of Sync
Message 5 of 10
gocker102293
I've also included the logs from the time around failure as well:
DescriptionCountLast OccurrenceTargetSource
[admin login] from source 192.168.0.252Wednesday, 13 Sep 2017 15:29:180.0.0.0192.168.0.25
[UPnP set event: urn:schemas-upnp-org:service:WANIPConnection:1#GetNATRSIPStatus] from source 192.168.0.251Wednesday, 13 Sep 2017 15:26:310.0.0.00.0.0.0
[UPnP set event: urn:schemas-upnp-org:service:WANIPConnection:1#GetConnectionTypeInfo] from source 192.168.0.251Wednesday, 13 Sep 2017 15:26:290.0.0.00.0.0.0
[DHCP IP: (192.168.0.25)] to MAC address d4:be:d9:30:81:6b1Wednesday, 13 Sep 2017 15:26:230.0.0.00.0.0.0
[DHCP IP: (192.168.0.24)] to MAC address dc:9b:9c:87:5d:0a1Wednesday, 13 Sep 2017 15:10:360.0.0.00.0.0.0
[UPnP set event: urn:schemas-upnp-org:service:WANIPConnection:1#AddPortMapping] from source 192.168.0.271Wednesday, 13 Sep 2017 15:07:510.0.0.00.0.0.0
[UPnP set event: urn:schemas-upnp-org:service:WANIPConnection:1#GetExternalIPAddress] from source 192.168.0.271Wednesday, 13 Sep 2017 15:07:480.0.0.00.0.0.0
[DHCP IP: (192.168.0.27)] to MAC address bc:83:85:65:4d:ad46Wednesday, 13 Sep 2017 15:07:450.0.0.00.0.0.0
[Time synchronized with ToD server]1Wednesday, 13 Sep 2017 15:04:500.0.0.00.0.0.0
[Initialized, firmware version: V2.01.14]1 0.0.0.00.0.0.0
Message 6 of 10
DarrenM
Hello gocker
I see you are getting T3 and T4 timeouts which typically signals toward a bad connection with your ISP you may want to have them send a tech out and check the levels in your home and out in your neighborhood.
DarrenM
Message 7 of 10
Smith3993
Guide
Message 8 of 10
gocker102293
You're a damn genius
Message 9 of 10
Smith3993
Guide
Thanks gocker102293,
I'm hardly a genius but I was determined not to have wasted $180 on a router that had me pulling my hair out! Glad I could help.
Message 10 of 10
Top Contributors
Discussion stats
  • 9 replies
  • 9676 views
  • 3 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
